VenderVendo FUJI Sportif 1.1 2014
gemuky
Mensaje por gemuky »
COLOR(S) Matte Black
MAIN FRAME A2-SL compact double-butted alloy w/ hydroformed top tube & down tube, integrated 1 1/2" lower head tube & PIIS BB86 shell, double water bottle mounts
REAR TRIANGLE A2-SL alloy tapered seatstays/chainstays w/ rack mount, forged-road disc dropout w/ 1 eyelet and replaceable derailleur hanger
FORK FC-770 Cross carbon blade, alloy crown w/ tapered alloy steerer & alloy dropout
CRANKSET Oval 520 forged alloy, 50/34T
BOTTOM BRACKET Press-fit BB86 sealed bearing
PEDALS N/A
FRONT DERAILLEUR Shimano Tiagra, band-type 34.9mm
REAR DERAILLEUR Shimano 105, 10-speed
SHIFTERS Shimano 105 STI shifter/brake combo, Flight Deck-compatible, 20-speed
CASSETTE SunRace, 11-32T, 10-speed
CHAIN KMC X10, 10-speed
WHEELSET Vera Corsa double-wall aero alloy clincher, 28/32H alloy road rims, alloy disc hubs
TIRES Vera Helios, 30 tpi, 700c x 28mm, wire bead w/ flat barrier
BRAKE SET Avid BB5 mechanical disc for road, 160mm / 140mm rotors
BRAKE LEVERS Shimano 105 STI
HEADSET FSA Orbit C-40, 1 1/8" upper - 1 1/2" lower, integrated
HANDLEBAR Oval 310 butted 6061 alloy, 31.8mm
STEM Oval 313 3D-forged 6061 alloy, 31.8mm, +/- 7 degrees
TAPE/GRIP Oval 300 suede-padded tape
SADDLE Oval R800
SEAT POST Oval 300 double-bolt, alloy 27.2mm x 350mm
WEIGHT, LB./KG. 22lbs / 10kg
SIZE S (49cm) Está semi-nueva, la vendo por no tener tiempo para usarla. Tengo la factura de compra de 1099€ La vendo por 750€ Se puede ver en singularbikes (Fuenlabrada)ImagenImagenImagenImagen
carbonotitanio
Re: Vendo FUJI Sportif 1.1 2014
Mensaje por carbonotitanio »
Hola buenas,aun dispones de la bicicleta.
