Although A Rising Tide might sound complicated at first, it's actually a fairly simple mission once you know the key locations. Most of the challenge comes from finding the Foreman's Apartment in Buried City and navigating the Controlled Access Zone in Dam Battlegrounds.
If you follow the steps outlined in this guide, you should be able to complete the quest smoothly on your first attempt without wandering around or losing valuable time. Suitable ARC Raiders Items can greatly help you.
Good luck out there, Raider.
In Arc Raiders, exploring new areas and completing quests is all part of the daily grind. With the new Shrouded Sky update, a familiar task resurfaces: a trip to Blue Gate. This time, the quest "Keeping an Eye Out" takes players to a tricky location near Barren Clearing, requiring a bit more than just following a path. The journey is full of acrobatics and timing, and if you're stuck trying to find Bilguun's shelter, don't worry. Here's a step-by-step guide to completing the quest and finding your way into Bilguun's hideout. A large number of ARC Raiders Items can also be of great help to you.
Where to Find Bilguun's Shelter in Arc Raiders
The first step in the Keeping an Eye Out quest involves locating Bilguun's shelter. According to Celeste, it's situated in the remains of a collapsed highway in the southwestern part of the map, specifically northwest of the Highway Collapse marker.
Once you've arrived in the area, you'll notice an opening within the ruins of the highway. This is your first clue-it's where you'll be heading.
Step-by-Step Directions:
Head to the collapsed highway: Travel to the southwestern part of the map, making sure to focus on the area near the Highway Collapse marker.
Look for the opening: Upon reaching the collapsed highway, you'll see an opening in the structure. This is where your journey begins.
Follow the road south: Once you've found the opening, walk south along the highway. You'll come across a ramp that you'll need to climb, leading you higher up onto the remains of the highway.
Find the zipline: At the edge of the highway, look for a zipline. This zipline will help you make the jump to the shelter, but you'll need precise timing to avoid falling to the ground.
Activate the zipline: Use the zipline to travel downward, and make sure to time your jump when nearing the end of the line to ensure you land right in front of Bilguun's shelter.
Alternative Methods to Reach Bilguun's Shelter
If you're finding the timing tricky and repeatedly crashing into the ground, there are a couple of other ways to make it into the shelter.
Method 1: Use Your Own Zipline
If you have a personal zipline, you can bring it along. Place it directly at the opening of the shelter, and use it to zip across. This can give you a bit more control over your path and help avoid the frustration of timing the zipline jump perfectly.
Method 2: Walk Backward Along the Collapsed Highway
Alternatively, you can stand at the edge of the collapsed highway, facing north. Slowly walk backward and position yourself so that, as you fall, you'll be able to maneuver in mid-air to grab the ledge of the shelter's opening. It might take a bit of practice, but with the right positioning, you'll be able to enter the shelter with ease.
Inside Bilguun's Shelter: Completing the Quest
Once inside Bilguun's shelter, your task is simple: approach the wall, and you'll be prompted to take a photo. Snap the photo to complete the Keeping an Eye Out quest.
Afterward, you can choose how you want to extract. You have two options:
Extract via the Airshaft: Head to the north of Broken Earth and extract using the Airshaft.
Continue Exploring: If you're not ready to leave just yet, feel free to continue exploring the Blue Gate.
Either way, completing the quest gives you a sense of accomplishment and unlocks more opportunities to explore this fascinating new area in Arc Raiders.
Tips for Success
Patience is Key: Timing your jump on the zipline can be tricky, but with some patience, you'll get the hang of it. Don't be discouraged if you don't make it on your first try.
Take Advantage of Tools: If you're still struggling with the jump, remember you can bring your own zipline or use the backward walking method for a more controlled approach.
Stay Calm: The Keeping an Eye Out quest may seem frustrating at first, but once you learn the ropes, it becomes much easier. Stay calm, focus on the task at hand, and don't rush.
Conclusion
The Keeping an Eye Out quest in Arc Raiders might sound simple on paper, but it requires some finesse to reach Bilguun's shelter. The key is to be patient and use the right techniques-whether it's timing the zipline jump perfectly, using your own zipline, or walking backward to grab the shelter's ledge. With this guide, you should be able to breeze through the quest and explore the secrets of the Shrouded Sky update with ease.
Every player needs a lot of ARC Raiders Coins, I suggest you go to a third-party website like MMOexp.com to buy, safe and comfortable transactions, and years of experience to ensure the security of your account.
