Gear choice in Arc Raiders isn't a "pick what looks cool" thing anymore, not with the March 5 meta shifts. You feel it the second you drop in: one clean fight and you're rich, one bad peek and you're donating your kit to the dirt. If you're still sorting your loadout around whatever you've got in stash, it helps to think in terms of what you can reliably replace, and what actually wins messy PvP. I've been using ARC Raiders Items as a quick reference point when I'm planning runs, because the game punishes guesswork way more than it used to.
The current "bring it every raid" picks
Il Toro is still the one weapon that rarely lets you down. They've tried to dial it back, sure, but it keeps doing the same job: solid damage, forgiving feel, and it doesn't demand some perfect attachment setup to function. The more interesting story is Burletta. People slept on it for ages, then suddenly everyone realised it's cheap to craft and it melts if you stay on target. The best part is the weight. You move quicker, you strafe better, and you can actually reposition instead of planting your feet and praying. In tight buildings or when a squad tries to collapse on you, that mobility matters more than a tiny stat bump on paper.
High-end toys that still pay off
If you've got the bankroll, Tempest and Bobcat are the flashy options that can absolutely carry fights. Tempest takes a minute, though. The recoil kicks like it's angry, and if you panic-spray you'll whiff and get punished. But once you pace your bursts and stop fighting the gun, it's brutal. Bobcat is the opposite vibe: it's not hard to use, it's just expensive to make "feel right." Without the right attachments it can feel weirdly underwhelming for the price, and that's what makes it a late-game flex. When you're comfortable losing a kitted Bobcat, you're probably already doing well.
Budget loadouts, range control, and what's falling off
For cheaper runs, Stitcher keeps showing up because it's simple and dependable. It won't carry you through every duel, but it'll keep you alive long enough to loot and rotate, and that's often the real goal. If you like playing slow and holding angles, Renegade is the cleanest mid-to-long range option right now; it just feels snappy and honest. Meanwhile, Kettle isn't the monster it used to be after the damage nerf. You can still make it work, but you've got to hit your shots, no excuses. And then there are the guns you see on bodies and understand immediately why they died: Harpin, Rattler, Anvil. They look fun, but in serious PvP they're liabilities.
Planning for survival, not highlight reels
The smartest loadouts are the ones you can rebuild without rage-crafting for an hour. Run Il Toro or Burletta when you want consistent fights, bring Tempest or a fully fed Bobcat when you're ready to gamble, and keep a Stitcher setup ready for "get in, get out" raids. A lot of players overthink damage charts and forget the boring stuff: ammo, weight, and how often you can replace what you're carrying. If you're trying to stabilise your runs, stock up on basics and keep an eye on ARC Raiders Common Material before you start chasing expensive builds that you can't comfortably sustain.U4GM's got that Arc Raiders energy: quick, useful tips and the gear to back it up.
Entrenamiento basado en Potencia ⇒ U4GM Arc Raiders Weapon Tier List Guide March 5 Updated
Hartmann846
